Astro Software v1.4 - What’s New
| UPDATE NOW |
New: Pilot Pro Integration
  • We just launched Pilot Pro and we think it's the best drone controller ever designed - learn more herearrow-up-right! Astro Software v1.4 brings support for the Pilot Pro and introduces new features with it including real time velocity control dials with the new Slow Speed Mode
New: Velocity Control (aka Slow Speed Mode)
  • Using the dials on the Pilot Pro allows for very accurate control of the Astro’s gimbal, ground and vertical velocities - ensuring smooth, consistent, and repeatable climbs or descents. Pilots can lower the velocity and vertical maximum speeds .1 m/s, such that a full stick command moves the machine at that maximum speed and climb rate.
  • Fine-Tuned Speed Adjustments: Pilots can set the velocity and vertical maximum speeds as low as 0.1 m/s. At this setting, a full stick command results in the drone moving at the specified maximum speed and climb rate.
  • High-Fidelity, Controlled Movements: By lowering the velocity clamps to a minimal setting, pilots can achieve highly precise and repeatable slow camera movements or climbs, offering exceptional control via the cyclic stick.
  • Seamless Mode Transition: Operate in the traditional Position Mode to fly at full speed. For operations requiring more finesse, such as a tower inspection or a cinematic shot, switch to the "Position Slow" mode, where the velocity limits set by the dials are engaged for more delicate maneuvers.
Operational Behavior Changes:
  • Mission and RTL Joystick Interaction: Moving the joysticks during Mission, Hold, or RTL modes will no longer switch to Position mode. For immediate stopping, press the Position mode button.
    • It's important to note that after executing certain automated actions, like Missions and Takeoff commands, the drone typically concludes with a Hold action. To regain manual control using the joysticks, operators must deliberately switch to Position mode.
  • Photo Trigger Feedback: Enhanced feedback in AMC UI during photo capture to prevent premature triggering of the next photo. Added error sound for capture failures.
  • Vehicle Timezone Configuration: Option to set the vehicle timezone on the Skynode web page. When set this will be used to name the photo folders based on the local time.
  • Failsafe Options for Wind Limit: Customizable failsafe actions if wind limit threshold is reached: Warning only, Return-To-Launch (RTL, default), and Land.
  • Gimbal Tilt Control Sensitivity: Added an option to adjust the sensitivity.
  • Rocker Dead Band Adjustment: New setting to fine-tune the rocker dead band.
User Interface (UI) Enhancements:
  • Quick Vehicle Overview Menu: Accessible via the vehicle indicator on the top bar's left side, featuring preflight checklists, safety settings, and system status.
  • Vehicle Menu Tab: Now hidden in normal mode, with essential tools available in the Quick Vehicle Overview Menu.
  • Tool Strip UI Revamp: Organized into Quick Actions, Flight Tools, and Map Tools, with improved accessibility and description tooltips.
  • Heading Indicator and Telemetry Dashboard: Redesigned for better map interaction and readability.
  • Unified Joystick and Radio Menu: Consolidated under the Controller menu.
  • Radio Tab Availability: Limited to RC-enabled vehicle configurations.
Status and Monitoring Improvements:
  • AMC Log Default: Logs are enabled by default with a retention of the last 10 files. Popup notifications for unhandled exceptions.
  • Magnetometer Interference Alerts: Notifications for detected interferences.
  • Enhanced Cellular Status Indicator: Detailed status display, including SIM card issues and connection rates.
  • Battery Charging Indicator: Now available for Android-based AMCs.
  • WiFi Settings Sync Fix: Resolved synchronization issues between WiFi settings and vehicle status.
  • PPK Status Enhancements:
    • New workflow API for progress status.
    • Fix for incorrect PPK status display in AMC.
  • In-Progress Download Display: Enhanced visibility of ongoing downloads.
  • UI Improvements: Better organization and navigation, including thumbnail resizing and navigation arrows.
  • Pinch-to-Zoom: Added for gallery images.
  • Download Optimizations: Various improvements to accelerate photo downloads.
Mapping and Mission Planning:
  • Mission Planning UI Structure: New tabbed interface for mission planning stages: "Start," "Mission," and "End."
  • Terrain Elevation Data Model: Transitioned to a new model hosted by Auterion, replacing the previous service that ended in June 2023.
  • KML Import and Mission Item Handling: Fixed KML import errors and improved mission item loading times and gimbal command execution.
  • Sony A7RIV Triggering: Improved consistency with reduced jitter during surveys.
  • Max Waypoint Distance: Increased to 1500 meters.
  • Unified Map Layer: Eliminates the need for map reloading when switching views.
Auterion Suite Integration:
  • New Onboarding Interface in AMC: Streamlined registration and setup process.
  • Feature Configuration Page: Customize Auterion Suite features in AMC.
  • Photo Upload Enhancements: Increased reliability, speed, and UI integration of photo uploads. Photos taken while disarmed won't upload.
  • Live Streaming Fix: Resolved issues causing video drops, ensuring stability across sessions.
Fixes and Improvements:
  • Video Stream Reliability: Improved the reliability of the video stream resuming automatically after a brief link loss
  • Video Recording Controls: Fixed Start/Stop/Toggle button functionalities for video recording.
  • Video Stream Duplication: Fixed an issue causing multiple streams, potentially overloading the radio link.
  • App Stability: Improved stability during vehicle connection changes.
  • MAVLink Command Processing: Removed command queuing for immediate execution and reliability.
  • Hold Command and Fly View Commands: Resolved execution issues related to missing terrain data.
  • Manual Control Failsafe: Improved handling during hold command execution.
  • Geofence Reposition Command: Addressed a corner case affecting hold commands.
  • Orbit Altitude Stability: Fixed altitude changes when adjusting speed.
  • Mission Start Bug: Fixed a bug causing the vehicle to get stuck in mission mode with idle motors.
Integrator Updates:
  • MAVLink Dialect Default in AMC: Changed to v2, enhancing initial communication efficiency.
  • Skynode Web UI Logging View: Added for comprehensive log monitoring from any application.
  • AuterionOS App Base Image Inclusion: Simplifies and accelerates app development.
  • MAVSDK Version Update: Upgraded to version 1.4.0.
  • MAVLink Tracker API: New API for integrating third-party object trackers with AMC.
  • Distance Metadata in XMP: Added for enhanced data capture.
  • Disarm Gesture Hysteresis: Introduced with adjustable COM_RC_DARM_A_H parameter.
  • MAV_0_FORWARD and COM_RC_OVERRIDE: Set to 0.
  • MIS_DIST_1WP: Set to 1500.
  • Wind Limit Failsafe Actions: Configurable via COM_WIND_MAX_ACT parameter.
| UPDATE NOW |
Last updated
