PPK Software
These free applications make it easy and simple to improve the accuracy of your survey through their use of Post Processed Kinematic corrections.
Freefly PPK
Freefly PPK Desktop Application takes photos and GPS data generated by Astro or Alta X Gen2 during a Mapping mission, as well as data from a GNSS base station, and applies the Post-Processing Kinematics (PPK) algorithm to tag photos with highly accurate geotags.
Current PC Version: v1.2.2 - Released 01/2026
Compatible Devices
Operating Systems
Windows PC - Tested on Windows 11
GNSS Base Stations
The following base stations have been tested, but generally any device that can output RINEX (Observation and Navigation data files) can be used
Trimble R2, 10, 12, R12i
Emlid RS2, RS4 Pro
Tersus Oscar
Input
Output folder from High Res Mapping Payload.
RINEX files (OBS and Nav Data files) from GNSS base station (that was actively recording GNSS data for the full duration of the time that the Astro mission was running).
GNSS base station coordinate
Using pre-surveyed point as reference coordinate
Using Reference Network calculation (i.e. NOAA's CORS, Washington state's WSRN)
For very basic results, averaged value from base station rinex file
Output
Photos in PPK_Photos folder with corrected geotags.
Workflow
1. Field Operations & Data Capture
Start the Base Station: Set up your GNSS base station and begin recording satellite data. Ensure you have a solid fix before flying.
Execute the Flight: Fly your mapping mission with your Astro or Alta X Gen2. Wait for the aircraft to finish processing photos after landing before powering down.
Firmware 2.1.3 Note: Ensure
GPS_DUMP_COMMis set to RTCM output (PPK) prior to flying. This is the default, but if you recently used RTK and changed this parameter, you must switch it back to get the PPK files.Blue Aircraft Note: Disable the
SDLOG_NO_POS_DATparameter prior to flying to ensure PPK files are generated.
Stop the Base Station: Once the flight is entirely complete, stop the base station capture and save the data in RINEX format.
2. Data Consolidation (Pre-Processing)
Retrieve Drone Data: Remove the USB-C drive from the aircraft, connect it to your computer, and locate the mission folder. It should contain your photos alongside the PPK artifacts:
imagelog.json,*sequence.json, and*capture.obsRetrieve Base Station Data: Locate your RINEX files. They typically end in
.<##>O(Observation),.<##>N(Navigation)Merge the Data: Copy the RINEX files directly into the mission folder alongside your photos and drone PPK files.
3. Freefly PPK Application Setup
Load the Project: Open the Freefly PPK app and click 'Browse for project...' to select your unified mission folder. The app will automatically scan and map the required files.
File Extension Fix: If files with a
26<x>extension aren't auto-detected, use the Modify button to link them manually, or rename them to25<x>and reselect the folder.
Define Base Station Coordinates:
Manual (High Accuracy): If the base station location is known, this will lead to the most accurate results. High accuracy base station coordinates are often from the base station being placed on a GCP, or using a correction network to give a better coordinate than the base station alone (e.g., WSRN, NOAA CORS). Enter the known ground coordinates as Decimal Degrees, or toggle DMS Coordinates box to input Degrees/Minutes/Seconds (ensure correct signs, e.g.,
-122for West).Average from OBS (Rough Estimate): Select AVERAGE FROM OBS from the dropdown. This applies single-point positioning for a quick estimate, which will appear in the status bar during processing.
Coordinate Systems: The HorizCS and VertCS fields are not used in data processing. These are used to update the photo tags, but do not influence processing. Setting these to the correct coordinate system may reduce steps on choosing your coordinate systems in your processing software.
Antenna Height: Enter the receiver height from the ground (check your tripod pole). The app will automatically adjust the antenna phase center based on the inputted height
If you corrected your base station coordinate with a reference network and your corrected coordinate is the phase center of the antenna, you do not need to input an antenna height. If you corrected for the ground point, you will still need to add antenna height.
Output Preferences: The default 'CSV and Photos' option will create a PPK_Photos folder to store the corrected images, but if reprocessed, it will overwrite the output folder with the current processing output. It is set to overwrite by default since the application can otherwise keep making copies of the photos and take up a lot of space on your computer. If the output type is set to 'CSV and New Photos', then the application will rename the previous folder and save the output of the current processing to PPK_Photos.
Offset:
Select the correct aircraft that gathered the dataset to ensure the correct offsets to the camera are applied during processing
When selecting a manual offset, the measurement will be from the center of the GPS antenna to the center of the camera sensor with X going forward, Y to the right, and Z down
Manual Offset Directions
4. Processing & Quality Validation
Run It: Click Process. Note: Do not close any pop-up command prompt or terminal windows that appear—these are running the background calculations.
Verify Quality (Q-Value): Monitor the output in the
PPK_Photosfolder. Your original images remain untouched. Check that most geotags read Q=1 (Fixed/Great) or Q=2 (Float/Okay). Anything higher is inaccurate.Once processing has completed, a new 'PPK Analysis Report' button will appear at the bottom of the app to further analyze your processing results
When opening the Analysis, this will open a browser window showing the original location, PPK'ed GPS antenna location, and the PPK'ed photo location
The top bar contains options to change the map layers between Normal (vector map), Satellite, or Mapbox. If choosing Mapbox, you will need to enter your Mapbox Token
If you select one of the points on the 2D map it will bring up additional information about the results, showing the photo and info about the PPK correction
By selecting '3D Plot' you can view a 3D graph showing the exact locations to spot check your PPK results. Each point can also be hovered over to show exact coordinates
In the 3D plot view, scrolling will zoom in and out, right-click and drag will reposition the chart, and left-click drag will rotate the chart
If you have any issues with Freefly PPK and have questions for the Freefly Support team (support@freeflysystems.com), it would help if you sent as many of your files as you are able to (i.e., contents of working directory, capture.obs, sequence.json, and base-directory folder). It also helps to include a screenshot of the application if there's an error.
Precise Flight
Precise Flight by Auterion is an alternative option for the PPK workflow. It can be downloaded when logged into the Auterion Suite
Last updated
