Skip to content
For the complete documentation index, see llms.txt. This page is also available as Markdown.
Output Specification
High Res Mapping Payload Output Specification
The standard workflow for mapping with Astro takes photos from the camera, geotags them, and writes them to the attached USB stick. The usb stick will contain data from each flight in separate folders.
Photos can be saved to either SD card or USB drive. When photos are saved to the SD card, no geotag is applied. However, all other files will be written to USB drive if one is connected, as well as small thumbs of the RAW photos.
Directory structure on the USB drive is as follows
Folder name
Naming: <SequentialFlightNumber>_<DATE>_<TIME>
There may be multiple folders that start with the same <SequentialFlightNumber> if photos were taken on the ground but without a flight.
Each folder will contain the following:
Observation file: <SequentialFlightNumber>_<DATE>_<TIME>.obs
This file contains the GNSS observations from the aircraft's RTK GPS, and is used in conjunction with the base station data to precisely locate the astro in space. The file also includes RTKlib-style "marker" entries at the timestamp when each photo was taken
Photo capture information file: <SequentialFlightNumber>_<DATE>_<TIME>-sequence.json
This JSON formatted file includes the precise timestamp and gimbal angle for each photo captured.
Aircraft capture state information file: imagelog.json
This JSON formatted file includes the aircraft position, attitude, timestamp, and capture url for each photo taken.
Name: YYYY-MM-DD-[SequentialNumber matching directory].json
Photos
File type: JPG
Naming: per camera settings
Geotags: Each photo is geotagged in its EXIF header, including geographic position and altitude in WGS84 (GPS) coordinate frame. The altitude in the aircraft geotags is based on the EGM96 geoid.
Note that additional tag information may be written later when post processed by a PPK app.
thumb
This folder contains small 512x341 thumbnails of the photos taken. They are geotagged as well, and are sometimes useful to upload to a photo photogrammetry site such as ESRI sitescan to ensure that photos are geotagged as expected. They can even be used to create a quick, coarse map.
Example output
Link to example datasets. These datasets have been copied from the USB drive attached to Astro.
Note that Base Station observation files are also included in separate folders in case you'd like to perform PPK.
Camera Calibration Parameters
This is a set of example calibration values for the Sony A7R-IV with Sigma 24 mm lens, which can be used for photogrammetry initial conditions. The LR1 also matches this specification with the 24mm lens. Each lens is slightly different, but these values are good initial values if the software in use can't solve them directly.
Parameter
Value
Focal Length (mm)
24.351
Principle Point X (pixels)
4714.485
Principle Point Y (pixels)
3172.286
R1
-0.017
R2
0.071
R3
0.009
T1
0.001
T2
Last updated
