> For the complete documentation index, see [llms.txt](https://docs.freeflysystems.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.freeflysystems.com/ecosystem/payloads/wiris-pro-thermal/technical-specs.md).
# Technical Specs
## General Info
<table data-header-hidden><thead><tr><th width="253"></th><th></th></tr></thead><tbody><tr><td>Weight (g)</td><td><p>Astro's maximum payload weight is 1500 grams.</p><p>Wiris Pro Payload (including gimbal) is ~940g</p></td></tr><tr><td>Dimensions (mm)</td><td>When upright and forward facing, the Wiris Pro payload alone has the maximum outer dimensions as follows: 150(width) x 157(length) x 162(height)</td></tr><tr><td>Ingress Protection</td><td>None</td></tr><tr><td>Mount</td><td>Smart Dovetail</td></tr><tr><td>Operation Temperature</td><td>-20C to +50C</td></tr></tbody></table>
#### Range of Motion:
Numbers are maximums from a forward-facing and horizon-leveled position.
| Pan                         | Roll                | Tilt              |
| +/- 170°. No continuous pan | 52° Left, 92° Right | 50° Up, 120° Down |
#### Flight Time
A single flight with Astro carrying the Wiris Pro Payload is typically 25-30 minutes. Note that the time presented in AMC is an estimate. The exact time depends on a number of factors such as temperature, air density, wind speed, and direction, as well as the flight profile of the aircraft.
{% hint style="info" %}
To extend flight times while focusing on a fixed area of interest, consider having Astro orbit around the area. In our testing, Astro is most efficient when orbiting at 7 m/s, rather than hovering. The orbit flight mode can be found by clicking on the map while on the ‘Fly’ screen, then clicking the orbit icon:
<img src="https://2546427254-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWXREyAKYAeQJ4gfg2SPg%2Fuploads%2Fgit-blob-519ae2dfdbb611fcfcc25b9b835ea0085f41d010%2Fimage%20(50).png?alt=media" alt="" data-size="original">
{% endhint %}
## Wiris Pro Camera Specs
#### Thermal Infrared Camera:
| Camera Modes                 | Photos at 640x512p, Video at 640x512p 30 FPS        |
| File Formats                 | <p>JPEG images</p><p>Radiometric TIFF images</p><p>Radiometric full-frame IR recording (raw data recording in 30 Hz)</p>        |
| Exposure Modes               | Auto, Manual, Custom Incremental        |
| Color Pallets                | BlackRed, BlueRed, BWIron, BWIronI, BWRainbow, BWRainbowHC, BWRGB, Fire, Gradient, Gray, GraySlowFade, Iron1, Iron2, Natural, Rainbow, RainbowHC, Sepia, Steps, Temperature, WBRGB                                                     |
| Sensor Resolution (pixels)   | 640px x 512px        |
| Lens Field of View (degrees) | <p>Wiris Pro Payload ships with a 13mm lens, approximately 45 x 37 degrees FOV (horizontal by vertical).</p><p><br><a href="https://workswell-thermal-camera.com/field-of-view-calculator/">Workswell Field of View Calculator</a></p> |
#### Visible Electro-Optic Camera:
| Camera Modes                            | Photo are 1920x1080px, video records at 720p 20 FPS        |
| File Formats                            | <p>JPEG images<br><br>h.264 (.mp4) video</p>        |
| Focus Mode                              | Continuous autofocus        |
| Sensor Resolution (pixels)              | 1920px x 1080px        |
| Sensor Size (mm)                        | 8.46mm (diagonal)        |
| Lens Horizontal Field of View (degrees) | <p>1x zoom → HFOV = 93.5 degrees</p><p>1.5x zoom → HFOV = 74.8 degrees</p><p>3x zoom → HFOV = 40.6 degrees</p><p>6x zoom → HFOV = 21.5 degrees</p><p>10x zoom → HFOV = 11.92 degrees</p> |
#### SSD capacity: 128GB
A full list of Wiris Pro specifications can be found on [Workswell’s website](https://workswell.eu/thermal-drone-camera-inspection-wiris-pro/).
# Agent Instructions
GET https://docs.freeflysystems.com/ecosystem/payloads/wiris-pro-thermal/technical-specs.md?ask=<question>&goal=<user_goal>
