> For the complete documentation index, see [llms.txt](https://docs.freeflysystems.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.freeflysystems.com/ecosystem/payloads/ventus-ogi/technical-specs.md).
# Technical Specs
## General Info
<table data-header-hidden><thead><tr><th width="253"></th><th></th></tr></thead><tbody><tr><td>Weight (g)</td><td><p>Astro's maximum payload weight is 1500 grams.</p><p>Ventus OGI Payload (including gimbal) is ~1,350g</p></td></tr><tr><td>Dimensions (mm)</td><td>When upright and forward facing, the Ventus OGI Payload alone has the maximum outer dimensions as follows: 170x 209 x 179 (WxLxH)</td></tr><tr><td>Ingress Protection</td><td>None</td></tr><tr><td>Mount</td><td>Smart Dovetail</td></tr><tr><td>Operation Temperature</td><td>-20C to +50C</td></tr></tbody></table>
#### Flight Time
A single flight with Astro carrying the OGI Payload is typically \~25 minutes. Note that the time presented in AMC is an estimate. The exact time depends on several factors, such as temperature, air density, wind speed, direction, and the aircraft's flight profile.
{% hint style="info" %}
To extend flight times while focusing on a fixed area of interest, consider having Astro orbit around the area. In our testing, Astro is most efficient when orbiting at 7 m/s rather than hovering. The orbit flight mode can be found by clicking on the map while on the ‘Fly’ screen, then clicking the orbit icon:
<img src="https://2546427254-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWXREyAKYAeQJ4gfg2SPg%2Fuploads%2Fgit-blob-519ae2dfdbb611fcfcc25b9b835ea0085f41d010%2Fimage%20(50).png?alt=media" alt="" data-size="original">
{% endhint %}
## Ventus OGI Camera Specs
#### Infrared Camera:
| Camera Modes                 | Photos at 640x480, Video at 640x480 30 FPS                                  |
| File Formats                 | JPEG and MPEG-TS                                                            |
| Sensor Resolution (pixels)   | 640px x 512px, 15 micron pitch                                              |
| Lens Field of View (degrees) | Ventus OGI Payload ships with a 25mm lens, approximately 21.7 degrees HFOV. |
A full list of the Ventus OGI specifications can be found on Sierra Olympia’s website:
<https://sierraolympia.com/product/ventus-ogi/>
# Agent Instructions
GET https://docs.freeflysystems.com/ecosystem/payloads/ventus-ogi/technical-specs.md?ask=<question>&goal=<user_goal>
