> For the complete documentation index, see [llms.txt](https://docs.freeflysystems.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.freeflysystems.com/ecosystem/payloads/third-party-payloads/hovermap-st-x-and-st-lidar.md).
# Hovermap ST-X and ST Lidar
| **Description**             | LiDAR with SLAM for GPS-denied environments |
| **Weight**                  | 1.6-1.7kg                                   |
| **NDAA Compliant**          | No                                          |
| **Offered By**              | Emesent                                     |
| **Latest Emesent Software** | Cortex v4.1.3 and Commander v2.2.1          |
The Emesent Hovermap ST-X and ST lidars are excellent payloads for creating detailed, accurate lidar point clouds, while enabling operations in challenging, GPS-denied environments.
<figure><img src="https://2546427254-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWXREyAKYAeQJ4gfg2SPg%2Fuploads%2Fgit-blob-fa593db1022696e9175221d443bf52cc89b0847f%2FScreenshot%202023-12-13%20at%2010.08.05%20AM.jpg?alt=media" alt=""><figcaption><p>Astro + Hovermap ST-X flying inside Alcatraz Cell House</p></figcaption></figure>
### Compatibility
<table><thead><tr><th>Drone Compatibility</th><th>Emesent ST<select><option value="SHv8oMwmiIbF" label="Yes" color="blue"></option><option value="eGG9b32rkoLv" label="No" color="blue"></option><option value="uC8MMpP6mCOA" label="Coming Soon" color="blue"></option></select></th><th>Emesent ST-X<select><option value="ig7orSicsUPZ" label="Yes" color="blue"></option><option value="ZSmD19mOwe80" label="No" color="blue"></option><option value="RgPFbTdmduQn" label="Coming Soon" color="blue"></option></select></th></tr></thead><tbody><tr><td>Astro (F45)</td><td><span data-option="eGG9b32rkoLv">No</span></td><td><span data-option="ig7orSicsUPZ">Yes</span></td></tr><tr><td>Astro Max</td><td><span data-option="SHv8oMwmiIbF">Yes</span></td><td><span data-option="ig7orSicsUPZ">Yes</span></td></tr><tr><td>Alta X</td><td><span data-option="eGG9b32rkoLv">No</span></td><td><span data-option="ZSmD19mOwe80">No</span></td></tr><tr><td>Alta X Gen2</td><td><span data-option="uC8MMpP6mCOA">Coming Soon</span></td><td><span data-option="RgPFbTdmduQn">Coming Soon</span></td></tr></tbody></table>
### Setting up Hovermap
{% content-ref url="/pages/tPXdecEjwhsGOeHZ6oJf" %}
[Hovermap Setup on Astro](https://docs.freeflysystems.com/ecosystem/payloads/third-party-payloads/hovermap-st-x-and-st-lidar/hovermap-setup-on-astro.md)
{% endcontent-ref %}
### Operation modes
Hovermap can interact with Astro as a passive payload, for mapping applications that can be flown with good GPS signal in open spaces with few obstacles.
{% content-ref url="/pages/KK5Y7d80GZYErxZ405yP" %}
[Mapping with Hovermap](https://docs.freeflysystems.com/ecosystem/payloads/third-party-payloads/hovermap-st-x-and-st-lidar/mapping-with-hovermap.md)
Hovermap can also use the lidar data of the environment around Astro, and build a 3D model in real time. It can use that data for obstacle avoidance, and even allow Astro to autonomously explore GPS-denied areas like under bridges and inside tunnels and mines.
{% embed url="<https://drive.google.com/file/d/1E1IJqVptU_CEoJ5mKBL6M3PxekiDd3TQ/view?usp=drive_link>" %}
Bridge scan with Hovermap ST-X
{% endembed %}
{% embed url="<https://youtu.be/045shpvB-m4>" %}
Astro navigating using Hovermap Assisted Mode
{% endembed %}
{% content-ref url="/pages/UDEtgqlGW566wudPkzi6" %}
[Assisted/Autonomous Flight](https://docs.freeflysystems.com/ecosystem/payloads/third-party-payloads/hovermap-st-x-and-st-lidar/assisted-autonomous-flight.md)
# Agent Instructions
GET https://docs.freeflysystems.com/ecosystem/payloads/third-party-payloads/hovermap-st-x-and-st-lidar.md?ask=<question>&goal=<user_goal>
