> For the complete documentation index, see [llms.txt](https://docs.freeflysystems.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.freeflysystems.com/ecosystem/payloads/payload-maintenance/payload-camera-firmware-update.md).
# Payload Camera Firmware Update
## LR1 Payload
LR1 cameras have shipped on versions 1.0, 2.0, and 3.0.
{% hint style="info" %}
To use APS-C mode, [update your LR1 camera to firmware v3.0 or later.](https://www.sony.com/electronics/support/camcorders-and-video-cameras-interchangeable-lens-camcorders/ilx-lr1/downloads) LR1 cameras on firmware v1.0.0 do not reliably accept the APS-C command. Early-batch LR1s (unit shipped before October 2024) are most likely to be on v1.0.0. APS-C mode is available on [Astro firmware 2.2](https://docs.freeflysystems.com/astro/maintenance/software-release-notes/astro-software-v2.2-whats-new)
{% endhint %}
To update your camera:
| Step        | Image        | Notes        |
| Download the firmware file from Sony and put it on to an ***empty*** SD card. Insert the SD card into the LR1 |        | [Sony LR1 Firmware](https://www.sony.com/electronics/support/camcorders-and-video-cameras-interchangeable-lens-camcorders/ilx-lr1/downloads)     |
| Remove the two screws on the back cover of the LR1 camera                                                     | <img src="https://2546427254-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWXREyAKYAeQJ4gfg2SPg%2Fuploads%2FKNhpL6ENLCVhGSTtEeUl%2Fimage.png?alt=media&amp;token=6e7746b3-295e-4d6d-a153-025b22325d26" alt="" data-size="original"> |        |
| Unplug the upper section of the GH cable on the payload. Remove any accessory module cables                   | <img src="https://2546427254-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWXREyAKYAeQJ4gfg2SPg%2Fuploads%2FEewKt1geJwgp6oT5BfgN%2Fimage.png?alt=media&amp;token=91dd3870-0cb2-4c42-b9e2-9678d91e60b4" alt="" data-size="original"> | This will prevent the aircraft from interfering with the camera during the update        |
| Gently remove the circuit board from the back of the camera, but keep the cables plugged in                   | <img src="https://2546427254-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWXREyAKYAeQJ4gfg2SPg%2Fuploads%2FB3JIF3LrJD5KIeGZrZls%2Fimage.png?alt=media&amp;token=9c1ad1d4-e8e9-4816-892a-a338b4a56bf6" alt="" data-size="original"> |        |
| Connect an HDMI cable and monitor to the camera                                                               | <img src="https://2546427254-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWXREyAKYAeQJ4gfg2SPg%2Fuploads%2FnsetrHA7Nz0LGxSCCpZH%2Fimage.png?alt=media&amp;token=fa9fc422-9f8a-45e3-ba73-7374b57dcff5" alt="" data-size="original"> | We recommend [this cable](https://store.freeflysystems.com/products/lightweight-right-angle-micro-to-standard-cable?_pos=7&_sid=10d9896d4&_ss=r) |
| Install the LR1 payload on the aircraft and power it on                                                       |        |        |
| Using the buttons on the camera, press Menu and navigate to the Setup -> Setup Option -> Version page         | <img src="https://2546427254-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWXREyAKYAeQJ4gfg2SPg%2Fuploads%2FlWX2P6o1VYoyMzTQz8aj%2Fimage.png?alt=media&amp;token=455eb269-db76-4ab4-bedf-683754598f1d" alt="" data-size="original"> |        |
| Follow the prompts to update the firmware        | <img src="https://2546427254-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWXREyAKYAeQJ4gfg2SPg%2Fuploads%2FfUH6NmWsuzRZpjtk8gPT%2Fimage.png?alt=media&amp;token=48242ed6-5eff-47ba-89fa-708841a71b22" alt="" data-size="original"> |        |
| Reinstall the circuit board, cables, and cover        |        |        |
## A7R4 Payload
We do not recommend updating the firmware on the A7R4. Most cameras were shipped with v1.10
## Wiris Pro Payload
{% content-ref url="/pages/mJQaCa6wu1mOisP3GlZH" %}
[Camera Software](https://docs.freeflysystems.com/ecosystem/payloads/wiris-pro-thermal/camera-software.md)
{% endcontent-ref %}
## Ventus OGI Payload
We do not recommend updating the firmware on the Ventus OGI Payload.
# Agent Instructions
GET https://docs.freeflysystems.com/ecosystem/payloads/payload-maintenance/payload-camera-firmware-update.md?ask=<question>&goal=<user_goal>
