LR1 Lenses and Expansion
Setup the LR1 Payload to fit your mission
Default Configuration
By default, the LR1 Payload comes balanced and tuned with the Sigma 24mm F3.5 lens, which covers most mapping applications. However, the gimbal can be re-configured with other lenses and external modules for other use cases!
Supported Lenses
Make sure to balance the gimbal after changing lenses! See the section below
Lens Settings
All compatible lenses will have settings to change the focus mode and adjust the aperture. For the LR1, which comes with a Sigma 24mm lens, we recommend you set these both to AUTO.
While it may be tempting to set these manually, setting the focus and aperture to AUTO will expose these settings to be modified any time in AMC.
Supported External Modules
The LR1 Payload currently supports two external modules from Freefly:
If you would like to integrate your own module, check out this section below:
Last updated
