Technical Specs
Scanner
Hesai 32M2X
Livox Avia
Ouster OS1
Channels LiDAR
32
128
Range
300 m
450 m
200 m
Field of View
360° x 40°
70° x 77°
360° x 42.4°
Laser Returns
Sensor Accuracy
±3 cm / 1.2 in
±5 cm / 2 in
±3 cm / 1.2 in
Precision
0.5 cm / 0.2 in
2 cm / 0.8 in
0.5 cm / 0.2 in
Points per Second (max possible)
1,920,000
720,000
5,242,880
Points per Second (nominal)
~0.6-1.1 M
~0.2-0.3 M
~0.6-1.1 M
RGB Camera (Ximea 20mp)
Internal precision IMU unit with 1°/hr gyroscopes
GNSS (Dual Full-band Receivers L1/L2/L5/L6)
INS solution
2000 Hz
2000 Hz
2000 Hz
Storage
USB-C drive (included)
Operating temperature range
-20C to +50C
-20C to +50C
-20C to +50C
Hardware Interface
Freefly Smart Dovetail
NDAA Compliant
Compatibility
Freefly Astro Freefly Alta X Gen2
Operating Temperatures
Freefly Flux is designed to operating in temperatures between -20 °C to 50 °C. When operated in an ambient temperature > 40 °C, the metallic surfaces of the sensor may be hot enough to potentially cause skin burn. Avoid skin contact with the sensor’s base, lid and the heatsink when the sensor is operated under these conditions.
When the sensor reaches the maximum operating temperature specified below, the sensor may become inactive and shut off.
Recommended Storage Conditions
Store the product in a dry, well-ventilated place. The recommended ambient temperature is 23±5°C, and the humidity between 30% and 70%.
Last updated
