For the complete documentation index, see llms.txt. This page is also available as Markdown.
Flux Software
Latest Software:
Release Notes
1.3.1
  • Improves IMU timing
  • Improves production processes
  • Adds build metadata
1.2.14
  • Fixes an issue where sometimes H1 units produce 0 pt scans
  • Add support for new IMU variant
1.1.0
  • Minor update to support hardware revision
1.0.0
  • Initial release for Freefly Flux L1, O1, and H1
Flux Update
To check Flux firmware version or update software:
  • Power on Flux while connected to Astro
  • Access to Flux Update Webpage at 192.168.144.233 from:
    • Pilot Pro tablet
    • iPad connected to Pilot Pro
    • Computer connected to pilot Pro via Ethernet
  • Access to Flux Update Webpage at 10.42.0.1 from:
    • USB-C Ethernet adapter connected to Flux Flux USB does not support USB device mode, a USB Network adapter must be used.
The webpage may need to be forced refreshed to see the current firmware version. This can be done by holding control + shift + R on windows or command + shift + R on mac
Software Version
The Flux software version is listed at the top of the page:
Web Software Update
  • Provide Flux software file
  • Update will validate file and install update
  • Flux will reboot once install is complete
  • Refresh web browser for version to update
USB Software Update
  • Format USB Storage on Flux via Flow App
  • Copy Flux software file to USB Storage root directory
  • Insert USB Storage into Flux
  • System will reboot if Software Update is a newer version
System Recovery
If Flux is not running correctly due to a failed or invalid update, System Recovery can be triggered by pressing Flux button when powering up. Recovery will execute the factory software instead of any installed update.
If an software update is present on the USB Storage, the factory software will install it and reboot. It is recommended to disconnect USB Storage when performing System Recovery to allow connection with the Flow App. Software update can be performed afterwards.
Last updated
