> For the complete documentation index, see [llms.txt](https://docs.freeflysystems.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.freeflysystems.com/ecosystem/payloads/a7r4-payload/resetting-camera-settings.md). Agents can also search and read this documentation through its [MCP server](https://docs.freeflysystems.com/~gitbook/mcp).
# Resetting Camera Settings
## **Resetting Camera to defaults for Astro Mapping**
{% hint style="warning" %}
Note: Normal usage should not require this process. Reset the camera settings only if the Freefly factory settings have been changed or you are having issues with your Mapping Payload and Freefly customer support has instructed this process.
{% endhint %}
The USB-C connector needs to be disconnected from the left side of the camera to reset the camera settings in Menu > Setup7 > Setting Reset > Camera Settings Reset. Use a thin driver to unplug and connect the USB-C, as it helps with the lack of clearance afforded by the gimbal.
![](https://2546427254-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWXREyAKYAeQJ4gfg2SPg%2Fuploads%2Fgit-blob-94d56965a7761b72679162d272783491cc00b6e2%2FMouse%20Highlight%20Overlay%202022-05-18%2016.26.15.png?alt=media)
![](https://2546427254-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWXREyAKYAeQJ4gfg2SPg%2Fuploads%2Fgit-blob-38499b7eb6af8091113f0524af4cbbdc991c06c1%2FMouse%20Highlight%20Overlay%202022-05-18%2016.26.40.png?alt=media)
Note! The camera will not save settings unless you turn off the camera using the switch on the camera and wait 45 seconds for the settings to save before removing power to the gimbal (turning Astro off or removing the gimbal from Astro).
{% endhint %}
## Changing Camera Settings
Setting can be changed on the rear screen of the A7R4. Most settings will presist across reboots unless they are controlled or specified by the aircraft
{% endhint %}
# Agent Instructions
GET https://docs.freeflysystems.com/ecosystem/payloads/a7r4-payload/resetting-camera-settings.md?ask=<question>&goal=<user_goal>
