> For the complete documentation index, see [llms.txt](https://docs.freeflysystems.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.freeflysystems.com/ecosystem/payloads/a7r4-payload/mapping-inspection-video-workflow.md). Agents can also search and read this documentation through its [MCP server](https://docs.freeflysystems.com/~gitbook/mcp).
# Mapping/Inspection/Video Workflow
## Mapping Workflow
{% content-ref url="/pages/mLb112E4Mgdl0roVmggP" %}
[Photogrammetry Mapping](https://docs.freeflysystems.com/ecosystem/workflows/photogrammetry-mapping.md)
{% endcontent-ref %}
## Inspection Workflow
{% content-ref url="/pages/giB3lfAupERCTgHUXgO3" %}
[Infrastructure Inspection](https://docs.freeflysystems.com/ecosystem/workflows/infrastructure-inspection.md)
## Video Workflow
A7R-IV payload is primarily intended for photos, but with some minor modifications it can be used to record video.
{% hint style="warning" %}
Astro Max (large motor variant of Astro) generally does not produce good video when flying the A7R4 Payload due to increased vibrations in flight
{% endhint %}
Data transfer to USB-C is not fast enough to record video at the Sony A7R-IV’s fidelity. As such, video needs to be recorded to the Sony A7R-IV's internal memory card. You will need to purchase a faster SD card in order to record at full quality. We have tested this [Lexar Professional SD card](https://www.amazon.com/dp/B07NLY7N7L/ref=cm_sw_r_api_i_BTVQ1733EN5HQKWWK8GJ_0?_encoding=UTF8\&psc=1), but any full-sized UHS-II SD card should work. You will also need to change the location to which the camera saves videos and images. Press the ![](https://freefly.gitbook.io/~gitbook/image?url=https%3A%2F%2F2177404587-files.gitbook.io%2F%7E%2Ffiles%2Fv0%2Fb%2Fgitbook-x-prod.appspot.com%2Fo%2Fspaces%252F8dwrGJhxGd9cIvsStziq%252Fuploads%252FukTmvrjPEog3ceQHegkv%252FSettingsIcon.png%3Falt%3Dmedia%26token%3Df6988f99-6ad7-4947-ab60-03d5ad9e8cb8\&width=44\&dpr=4\&quality=100\&sign=3bd787d9\&sv=1) icon on the right of the screen while in Photo Mode, and change the Image Storage dropdown to Camera.
# Agent Instructions
GET https://docs.freeflysystems.com/ecosystem/payloads/a7r4-payload/mapping-inspection-video-workflow.md?ask=<question>&goal=<user_goal>
