Doodle Binding / Pairing
Ensure that your air and ground radios are at least 2 feet apart. Doodle radios are powerful, and if they are too close, they may create interference with each other.
Power on the Drone with one battery.
Power on Pilot Pro.
Give it time. Each radio takes about 60 seconds from power-up to fully boot its system. Ensure both the air and ground radios have been powered on for at least 60 seconds before checking connectivity.
Open the Pilot Pro App and open the side menu. Navigate to "Radio Settings".
Open "Pairing Manager" tab
Find the bind button under the Drone. Its next to the yellow XT connector on the IO Panel.
Press on the bind button 3 times quickly. Then make sure the boom LEDs starts blinking white to indicate the Radio went into Binding mode.
The boom LEDs blink during pairing only on drone firmware v2.3.7 or later.
Then press Scan in the Pilot Pro App. From the list of results, find the one that matches the Drone's serial number. Then press pair.
Wait until the Pilot Pro app says Pairing Successful and the boom LEDs go back to its original colors.
Last updated
