For the complete documentation index, see llms.txt. This page is also available as Markdown.
Software Interfaces
Apps
The Pilot Pro controller runs a modified Android firmware on its Samsung tablet, and provides users with the opportunity to customize their setup. Apps can be installed on the tablet to enhance functionality. The Samsung device is running an Android 13 base image. Most APK files will be compatible with it, offering a variety of possibilities such as installing a weather app, or a flight restriction app, or even a custom app to interact with the drone.
The user will need to enter their google credentials and use the play store, or download an apk and install by using a trusted installer app the user has assigned.
Google account
The Pilot Pro's tablet does not ship with a default google account. This somewhat restricts the ability to communicate with the google appstore and other google services. Users can opt in to this functionality by providing their google account information to the tablet, which will allow appstore, personalized settings, and all the other Google ecosystem benefits of having an account logged in.
Debugging
USB debugging is available on this device, but it is not enabled by default. Users can enable it at their peril...
Pilot Pro has a Host Swap mode that will activate the bottom right USB port as the host, and make the Tablet a device in the USB hub. This allows for:
  • ADB access over USB to the Tablet for App development
  • HID device access for reading joysticks, rockers and buttons
To enter Host Swap mode, either select ‘Restart Controller with Host Swap’ from the Advanced Menu in the Pilot Pro App. While in this mode, the screen will display "External USB Host". To exit Host Swap mode, simply reboot the controller.
While in Host Swap mode, the controller and tablet are no longer linked. The Pilot Pro App will not detect the controller and the tablet's power button cannot be used to power it off.
If you're trying to connect the controller to a computer as an HID input, you will need to set AuthKeyEN to 0 in the Pilot Pro app -> Controller Settings
Drone connection
The Pilot Pro offers a mechanism for external devices to connect to the drone directly. See the Connecting to the drone via the RJ45 cable section for information on connecting to the drone from 3rd party devices.
Payload connection
It is also possible to connect a payload to the network as well and access it directly on some drones such as Astro.
Using Astro as an example, a lidar could be mounted to Astro's smart dovetail and connect its ethernet port to the ethernet pins in the connector. The lidar would be assigned an IP address in the range specified by the connectivity section, ensuring there are no IP conflicts. Then, a web browser or app on the tablet could access it directly through its 192.168.144.* ip address for configuration or monitoring. A computer or tablet connected through the RJ45 port could also access it.
Block Diagram
To support integration efforts, the following block diagram details the controller's internal connections.
Block diagram of the controller's data paths
Block diagram of the controller's internal data paths
Last updated
