> For the complete documentation index, see [llms.txt](https://docs.freeflysystems.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.freeflysystems.com/alta-x-gen2/maintenance/software-updates/updating-firmware.md).
# Updating Firmware
## Updating Alta X Gen2 Firmware
{% hint style="info" %}
You can determine if Alta X Gen2 needs an update by following steps 2-4 below. The current firmware version is available on the [Software Updates](https://docs.freeflysystems.com/alta-x-gen2/maintenance/software-updates.md) page.
{% endhint %}
1. Download the firmware from the [Current Firmware Version](https://docs.freeflysystems.com/alta-x-gen2/maintenance/software-updates.md#current-firmware-version) section of the Software Updates page.
2. Connect Alta X Gen2 to your computer with a USB cable.
3. Power on aircraft **with one battery through the fused cable** and wait about 15 seconds for aircraft to fully boot.
4. Using a browser such as Chrome or Safari, open the aircraft's info/update page at [http://10.41.1.1](http://10.41.1.1/) (internet connection is not needed).
5. In the Update Auterion OS box, click Browse, and select the firmware file downloaded above.
   <figure><img src="https://3598791290-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FmvvtTxCd0o4luBB04PQp%2Fuploads%2F9bJ1WP1fwWnVrHkWSZsc%2Fimage.png?alt=media&amp;token=781160ec-fc60-4c7a-9d08-7fa07dcb0bcb" alt="" width="563"><figcaption></figcaption></figure>
6. Click Update and wait 10 mins for the process to complete.
7. After the update completion message, verify that the webpage shows a "Release name" that matches the downloaded file and that all the boom LEDs are on.
   <figure><img src="https://3598791290-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FmvvtTxCd0o4luBB04PQp%2Fuploads%2FLyx3MubIhHeMwPleF1aW%2FScreenshot%20from%202026-01-23%2012-38-48.png?alt=media&amp;token=41b91986-0d2a-46a9-87e5-c0f57c031e68" alt=""><figcaption></figcaption></figure>
If the aircraft gives an error message, power cycle the aircraft and try again.
{% hint style="warning" %}
**If your Alta X Gen2 firmware update fails:**
1. Update the Pilot Pro App to v2.7 or later.
2. Connect Pilot Pro to your Alta X Gen2.
3. Tap the **Fix Me** button in Pilot Pro, which will apply the *FW Updater Fix*. This is found in:\
   `App Menu > Vehicle Status Page`
4. If you have a Blue/NDAA Alta X Gen2, you will need to disable Admin Protection on the 10.41.1.1/settings page before the *FW Updater Fix* can apply. Admin Protection can be re-enabled after the firmware update is successful.
5. Retry the Alta X Gen2 firmware update once the *FW Updater Fix* has been applied.
   {% endhint %}
After updating the aircraft, make sure that all apps in the Freefly Updater on Pilot Pro are [up to date](https://docs.freeflysystems.com/ecosystem/controller/pilot-pro/maintenance/software-and-firmware-updates).
## How to Reset to Default Alta X Gen2 Parameters
* Open AMC and activate Advanced mode
* Connect AMC to Alta X Gen2
* Select: Vehicle setup > Parameters > Tools > Reset to vehicle's configuration defaults.
* Reboot Vehicle
* Calibrate sensors as required
<figure><img src="https://3598791290-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FmvvtTxCd0o4luBB04PQp%2Fuploads%2Fgit-blob-7ef49651fa70c14954eff77f8b94a0324dc074fd%2FScreenshot%202024-03-29%20at%2012.13.19%20PM.png?alt=media" alt=""><figcaption></figcaption></figure>
# Agent Instructions
GET https://docs.freeflysystems.com/alta-x-gen2/maintenance/software-updates/updating-firmware.md?ask=<question>&goal=<user_goal>
